1. allysonven's Avatar
    So...I get a call from someone I don't know, the number is there is my call log, I would like to save this number to a new or existing contact, and...WOW there is no way to do it! I highlight it like I used to, but the only option is to delete the call from the log. Not only can I not create a contact from the call log, but I cant copy it to paste later in the contacts area. I have also found out that I can't paste:confused into the dial pad anymore. This is a pain when I am online and copy a number I need to call. Now I have to use pen and paper to write the numbers down to accomplish both of these things.
    The lack of the menu button is a bit of a sad thing too. I miss it over there to the left of the center button. Now I have no easy way to see what I can do within any given area.
    I know these issues seem small, but I have had the phone for 3 days, and it's bugging me.
    04-15-2015 01:37 PM
  2. atishc's Avatar
    You just tap on the phone number in the call log, then it opens up a new screen, where you can "Create Contact" or "Update Existing". You paste a number into the dialer by long pressing in the area that the phone number appears when you dial. Any time an app has a menu, there should either be a three vertical dot orientation or "More" in the upper right. The really annoying thing is that in some Google apps you have to slide in a menu from the left, but there is no way you would know that ahead of time.
    Hopefully this helps.
    04-15-2015 03:21 PM
  1. Help with Chromebook or laptop decision.
    By Deegan in forum Ask a Question
    Last Post: 04-17-2015, 07:15 PM
  2. Replies: 2
    Last Post: 04-17-2015, 05:35 PM
  3. Best 5.1 feature
    By tr-1 in forum Android 5.0 Lollipop
    Last Post: 04-15-2015, 09:08 PM
  4. Can I get some help removing hardporncheck.com virus?
    By thoit23 in forum Samsung Galaxy Note 4
    Last Post: 04-15-2015, 11:23 AM
  5. Replies: 1
    Last Post: 04-15-2015, 10:56 AM
