1. NathanCCI's Avatar
    Has anyone found a kickstand case that works with wireless charging?
    On a different note, I bought the Samsung S-view flip case and it works fine with my Samsung Qi charger but not with either of my Duracell Powermat chargers. Anyone having luck with the S-view flip case and Powermat chargers?
    Posted via the Android Central App on Samsung GS6
    04-18-2015 06:29 PM
  2. jcp007's Avatar
    Don't have a kickstand case. If it will work on a Defender case, there should be no issue at least with the OEM charging pad. Check out my YouTube video review in which I test wireless charging with the Defender.
    04-18-2015 06:38 PM
  3. mistyisland's Avatar
    I have one of those Verus slide cases that can hold a couple of credit cards in the back, and it is charging fine on that cheesy $3.00 wireless charger from eBay someone posted a while ago. So actually I guess the only thing cheesy was the price.
    Here's the charger:
    http://rover.ebay.com/rover/1/711-53...item2edba4a111
    04-18-2015 07:10 PM
  4. NathanCCI's Avatar
    Thank you both for your replies. I was hesitant to just purchase any old kickstand case because of the problems with the S-view flip cover and the powermat chargers. JCP, can you provide a link to your Youtube video?
    Thanks,
    Nathan
    04-18-2015 11:00 PM
  1. Replies: 61
    Last Post: 04-20-2015, 10:38 AM
  2. Note 10.1 (2014) not syncing S-notes with Note 4
    By jodroid03 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-19-2015, 02:07 AM
  3. S6 - Are there any requirements for quick charging?
    By Punkrulz in forum Samsung Galaxy S6
    Last Post: 04-19-2015, 01:30 AM
  4. charging s3 battery in a s4
    By scarpit12 in forum Samsung Galaxy S3
    Last Post: 04-18-2015, 06:27 PM
  5. How do I open more than one app with Android 5.0 Samsung S5?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 04-18-2015, 04:09 PM
