Some reason it keeps blinking blue and sometimes it turns off completely. No lights. This is the Samsung charger they offer with the deal. Any ideas?
There is something wrong with the Samsung wireless chargers. I have 2 of them and they act as yours does, shut off and quit charging letting the phone drain.
I have 2 Duracell Powermats and they work fine. Bring the phone to 100% and then cycle on and off to keep it nearly there until I pick up the phone. There are also MUCH easier to get the phone to start charging.
What a deal, BestBuy was charging over 100.00 dollars more for the phone off contract than the carriers, and if you get your plan through them they were charging more for that too. As far as chargers are concerned, I stick to ones that have 3 charging cores instead of just one, you don't have to be precise when placing the phone on the charger, and I like ones that put out at least 12 volts, many only put out 5 volts making it difficult to power through some cases.
Solid blue means charging and green means done but this charger will randomly blink blue in the middle of the night and sometimes just completely turn off.I believe that the blue means that it is properly aligned and green means that it's done.
Posted via My Samsung Galaxy S6 Handheld Device
I have the Samsung Wireless Charger and mine charges fine. It stays green even after charging is complete. Do you guys use Power Saving mode while charging?
Sent from my ATT Galaxy S6 using Tapatalk
Nope. You should disable it and see if that's the problem...I do use power saving mode while charging at night. Do you not? I didn't even think about that being an issue.
I had a lot of problems with the S6 Samsung Charging Pad (I ordered mine direct from Samsung). I was finding the exact same issues as you have stated; waking up in the morning to find the blue light flashing, charge at about 96%. I ended up mailing it back to Samsung for a refund. Many reviewers have found that the phone is actually moving around on its own ever so slightly over a long period of time, which is causing the charging issue.Nope. That wasn't it. Still turned off
That is weird. I guess mine doesn't slide off...I had a lot of problems with the S6 Samsung Charging Pad (I ordered mine direct from Samsung). I was finding the exact same issues as you have stated; waking up in the morning to find the blue light flashing, charge at about 96%. I ended up mailing it back to Samsung for a refund. Many reviewers have found that the phone is actually moving around on its own ever so slightly over a long period of time, which is causing the charging issue.
Oddly enough, my favorite, and most reliable Qi wireless charger has been the wireless charger introduced with the S4. I've never had any issues with charging and it is always at 100% when I wake up. The design doesn't allow for movement since it curves up on the edges, and there isn't any "searching" for a sweet-spot. These have been my observations. Link below on Amazon.
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4375734
