Originally Posted by
Brian Delaney No. I get the draining with WiFi totally off. I just turned off VOLTE, so im.hoping it makes a difference. If not , then I'll have to see if it is worth it with the fast charger, charging case or to return it
With so many people around here I don't really remember if you have posted some screenshots of your battery usage, I mean, if in your case with Wifi Off you still have drain, and it's not the VoLTE that I thought everybody with these issues should be turning off until there is a fix, then you may have a rogue app, or even the infamous Google Play Services draining your battery.
Post more detailed information to see if we can see what nay be wrong in your case, if not, then get a replacement while you can,
