1. Owen Kim's Avatar
    For those of you are not getting screen on time for more than 3 hours in daily use,
    Just in case you haven't done so,
    Go to location settings and change the settings to this. You can still get good location features with this, but with much more improved battery life. I was not able to hit 4 of screen on time at all but now I can by simply doing this!
    Attached Thumbnails Increase battery life drastically with location settings-106.jpg
    04-22-2015 08:17 PM
  2. jschu22's Avatar
    I don't think map or navigation accuracy is good enough with just that setting. I could be wrong though.
    04-22-2015 08:29 PM
  3. 20blks's Avatar
    You can change it to the more accurate setting when you're turn by turn navigation. Otherwise, the middle setting will do just fine
    04-22-2015 08:31 PM
  1. Can I get some help with Note 4 battery problems?
    Last Post: 04-25-2015, 03:16 PM
  2. Pandora stopped working with 2011 Ford Edge
    By isabel95 in forum Samsung Galaxy Note 4
    Last Post: 04-23-2015, 11:10 AM
  3. Nexus 7 with hot spot or as phone replacement?
    By DestructoGirl in forum Google Nexus 7 Tablet (2012)
    Last Post: 04-23-2015, 01:31 AM
  4. Replies: 1
    Last Post: 04-22-2015, 08:05 PM
  5. lock screen privacy settings
    By techyforyou in forum Samsung Galaxy S6 edge
    Last Post: 04-22-2015, 05:46 PM
