1. AC Question's Avatar
    Greetings! I am a iPhone convert and couldn't be happier. I just got the Galaxy S6 which of course is running Lollipop. One of the features I used all the time on my iPhone was the ability to skip forward/back while listening to music (e.g. Pandora, Rhapsody, Music Player, etc.). I'm afraid to ask but am I to understand this functionality does NOT work on this phone/OS??? If so, how can I get around this? I do not want to root the phone nor do I want to be forced to use apps that require me to play music stored on the phone. I have subscriptions to Pandora and Rhapsody for a reason. Frankly, had I known this was the case I probably would have stuck with the iPhone.
    I know similar questions have been asked but none provide clear solutions. Most result in several variations of... "you should use Poweramp".
    04-23-2015 12:50 PM
  2. tlo07's Avatar
    I believe you can do this with headphones made for Android. I'm sure the ones that came in the box must be able to do this? I haven't even unwrapped mine so I can't say for sure. Anyway, I have some nice Bose MIE2i headphones that I use with my iPhone but if I want the same functionality (volume, skipping) with my GS6 I have to buy the pair made for Android.
    Bose actually has some that say "for Samsung Galaxy phones" and they advertise the in-line controls being able to adjust volume and skip tracks.
    Sent from my iPad using Tapatalk HD
    04-23-2015 10:06 PM
  3. dpham00's Avatar
    On some headphones, you can double click the play button to skip forward, triple click to skip backwards
    Sent from my Pearly White Verizon Samsung Galaxy S6 Edge
    04-24-2015 12:31 AM
  1. Hangouts App fails miserably on Droid Turbo
    By sethgoldstein in forum Motorola Droid Turbo
    Last Post: 08-16-2016, 10:45 AM
  2. S5 won't turn on.
    By Iainmac963 in forum Samsung Galaxy S5
    Last Post: 10-05-2015, 07:58 PM
  3. Replies: 1
    Last Post: 04-24-2015, 05:04 PM
  4. Will a Sprint Edge work on Verizon if unlocked?
    By jamestss21 in forum Samsung Galaxy S6 edge
    Last Post: 04-23-2015, 08:21 PM
  5. Use same SSID, password for travel router as home?
    By whitenack in forum Google Chromecast
    Last Post: 04-23-2015, 11:54 AM
