Hey Guys,
I moved from a Note 4 to a Galaxy S6 64 GB.
i am going to share what i have been through with this Galaxy S6.
When i opened the sealed box i discovered that the simtray was not made so perfectly(picture). At the first moment i was dissapointed, but than i was like : let me try this phone out.
I started the Galaxy S6. It loaded fast, i signed in with all my accounts. Everything seemed to be Oke. But than i saw that white was not real white in the corners at the bottom of the screen. It is pinkish and in the middle a bit yellow. it was not really an issue for me cause i am used to these problems on other devices( I have owned all the samsung S and Note series)
I was inspecting the glass at the back and i saw a scratch. i used my shirt to wipe it but than it seemed to be inside the glass. Hmmm. ( see the picture yourself)
I looked at the front glass and saw more problems, the right corner at the bottom is more inside the frame than the left corner. The left corner is in 1 line with the frame.( picture )
Than at the top : when i press on the screen , i can see the glass moving and even when pressing at the bezel side the glass moves.
I bought the S6 on the 21st of april , today the 26th of april the samsung gave more problems. The battery was more than 50 percent. i left it on the table and when i came back after 1 or 2 minutes to pick it up the phone couldnt go on anymore. I pressed and holded the power button, but no action. i tried to plug it into the the charger , nothing happened, not even the led light nor a screen that the phone is charging. I plugged in on my pc and no connection, the pc couldnt find any usb/media.
I have used all types of samsung phones, but this one is the Worst. i was so happy with my Note 4 but i saw the camera of the S6 and thats why i switched to the S6. The camera is really good and have never seen so beautifull selfies with a phone.
The phone has warranty so i will bring it there but wont get a new phone, they will repair it ( that what they( T-Mobile Netherland) told me through the phone.
* belief me, i am a Android-Fan and user and dislike apple ( for those who are thinking that i am bashing Android/Samsung)*
Are there more of you having problems with the S6?
