Saw this as well
I was surprised that the G4 had wireless charging but the S6 has both standards...also the fingerprint scanner I like and prefer than any other method
Sent from my Samsung Galaxy S6!
Bigger screen is a huge negative for me. G4 is not a true one-handed device. Good luck reaching the menu button on the G4 with one hand.
And as someone pointed out in the comments, the higher screen to body ratio is cancelled out by the on screen navigation buttons on the G4.
Putting power and volume on back makes a lot of sense. Very easy to adjust volume and take a screen shot. I miss the back buttons whenever I use non LG devices.Who puts the power button and volume rocker on the back?
Posted via My Samsung Galaxy S6 Handheld Device
Sent from my LG G2 running CM 12
It's not difficult at all and I've never pressed power or volume by mistake.You can also hit them by mistake. You shouldn't have to resort to yoga to power on the phone or change the volume.
While it might seem odd at first, the back buttons on the G3 are amazingly easy to use and you'll never hit them by mistake like on a Samsung phone.
Not a problem if you use an app like Car Home Ultra.Not unless it is on a car mount. When I had the G3, it just took a lot more steps to get where you wanted cause the buttons were covered. (And no, I did not drive and use the phone at the same time)
