1. trai_lguy's Avatar
    Hello I am new here. I have read a lot of posts but found no answers. Is there a fix for the WiFi issues? Or is there a update coming? Maybe 5.1.1 will fix it. Sorry if I am beating a dead horse.
    05-03-2015 11:47 PM
  2. shadow82x's Avatar
    What's wrong with the wifi? I'm not seeing anything. o.0 Are you referring to the cell standby drain?
    05-04-2015 12:56 AM
  3. Almeuit's Avatar
    What issues are you having?
    05-04-2015 12:58 AM
  4. dmarcus48's Avatar
    I'm on Verizon, I don't have any issues with my wifi.
    05-04-2015 10:37 AM
  5. trai_lguy's Avatar
    The problem is that it says that I am connected to my network but when I try to do anything on the Internet it says that I have no network connection even though the WiFi icon shows that it's connected.
    05-04-2015 10:45 AM
  6. Almeuit's Avatar
    Is this with your home wifi or a public one? If the internet is down that the wifi uses you could be seeing this issue.
    05-04-2015 10:47 AM
  7. trai_lguy's Avatar
    it is my home network. my wifes S5 has no problem with the connection.
    05-04-2015 10:57 AM
  8. trai_lguy's Avatar
    I went ahead and replace my router and seems to have fixed the problem.
    Thanks.
    05-04-2015 02:08 PM
  1. Will the Samsung Gear S work with Galaxy S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 09-17-2015, 10:34 PM
  2. rooting Verizon gs5
    By jakeharr5 in forum Samsung Galaxy S5
    Last Post: 05-06-2015, 05:19 PM
  3. How can I unzip a Samsung firmware file?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 05-04-2015, 02:13 AM
  4. Can I get some help restoring my Google Back up to my new S5?
    By manonlescaut40 in forum Samsung Galaxy S5
    Last Post: 05-03-2015, 11:30 PM
  5. Why am I unable to charge my Samsung Note 4?
    By yi7682 in forum Samsung Galaxy Note 4
    Last Post: 05-03-2015, 11:08 PM
