1. kyle.brown's Avatar
    Does anyone know an easy way to remove the case? I seem to struggle with it. The Neo Hybrid Metal case is so easy to take off but for some reason i feel like i am bending the phone when i remove the normal Neo Hybrid.
    05-08-2015 08:11 AM
  2. deeb215's Avatar
    Are you removing the bumper first or both pieces at once? You have to remove that first and then the TPU case.
    kyle.brown likes this.
    05-08-2015 08:23 AM
  3. kicko's Avatar
    I pick a corner, say the upper right, and with a little force but being careful slide it back. Once you get one corner off the plastic band comes off very easily. Remember need always need to remove it front to back. it will never come off forward due to the designed edge to make it sit flush.
    05-08-2015 12:29 PM
  4. kyle.brown's Avatar
    Ah i will try that i know its super easy on the metal Neo Hybrid but for some reason i have the hardest time on the normal one.
    05-08-2015 12:50 PM
  5. RFish86's Avatar
    Try and pick it by the power button and work that corner off instead of trying to pick it right by the corner at the start. The corners are too tight to lift first I find.
    05-08-2015 01:16 PM
  1. Replies: 5
    Last Post: 06-19-2015, 01:06 PM
  2. Replies: 8
    Last Post: 05-08-2015, 07:33 PM
  3. Replies: 1
    Last Post: 05-08-2015, 08:25 AM
  4. Replies: 1
    Last Post: 05-08-2015, 07:05 AM
  5. Help upgrading OS on rooted S4
    By dzegers in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 05-08-2015, 06:25 AM
