1. Kalvin Kerns's Avatar
    Yesterday I picked up this great new companion to my S6. So far it's a gorgeous, high quality piece of kit that I highly recommend.
    Great design with water and sweat residence. Battery lasts 6 hours plus another 10 from the charging case that comes with it. I think it looks and feels comfortable on as well. I didn't even need to try one of the extra ear pieces that came with it. Was prefect right out of the box. Expensive at $129 from Best Buy, but hopefully worth it. Check out it.
    Attached Thumbnails Plantronics Voyager Edge got my S6-20150511_131508.jpg   Plantronics Voyager Edge got my S6-20150511_134616.jpg   Plantronics Voyager Edge got my S6-20150511_134710.jpg   Plantronics Voyager Edge got my S6-20150511_154115.jpg   Plantronics Voyager Edge got my S6-20150511_154025.jpg
    Plantronics Voyager Edge got my S6-20150511_154125.jpg   Plantronics Voyager Edge got my S6-20150511_135725.jpg
    Daspoo likes this.
    05-12-2015 12:40 PM
  2. Gator352's Avatar
    I've been using that BT for about 7 months now. It works and sounds great. I installed the companion app on my phone and PC to make the most of its features also.
    The only downside is that the rubber earpieces wear really quick but you can get replacements at plantronics.c0m or on amazon.
    Enjoy it as it's a great BT!
    05-12-2015 03:11 PM
  3. Kalvin Kerns's Avatar
    Actually I believe you turned me onto it lol.
    Now I just need to update the firmware, hopefully tonight. I installed the Findmy headset app, it has good reviews.
    05-12-2015 03:45 PM
  1. Replies: 7
    Last Post: 06-04-2015, 12:12 AM
  2. Why can't I mirror link to my Pioneer app radio 4 ?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-24-2015, 06:26 PM
  3. Replies: 1
    Last Post: 05-23-2015, 12:37 AM
  4. There is a strange icon at the top of my phone. What could it be?
    Last Post: 05-13-2015, 08:35 PM
  5. Why does my Android tablet keep crashing?
    Last Post: 05-12-2015, 05:19 PM
