1. Taz89's Avatar
    Hey guys and girls just wondering is anyone having issues with no info being shown in the battery section. Example instead of saying for example 6 hours left of usage it just keeps saying still learning usage habit. It was showing before but I did a factory reset and for a day it's been like this. Previously it was giving me info out the box and even when I did a reset before I was getting data instantly.
    05-13-2015 08:17 AM
  2. deeb215's Avatar
    I had this happen and eventually had to do another factory reset to get it fixed.
    05-13-2015 08:47 AM
  3. Taz89's Avatar
    Hmm yep not doing another factory reset. Hopefully it fixes itself eventually or a future update fixes it. Certainly not worth re setting my s6 all over again. I still get the important battery usage data so that's fine.
    05-13-2015 08:59 AM
  4. erasat's Avatar
    Let it drain until at least 10%, then try doing a Wipe cache partition in Recovery Mode (Power Off then Press and Hold Power, Home and Vol-up buttons until the android appears) and after reboot put it to charge to 100%. See if that helps.
    05-13-2015 09:04 AM
  5. Taz89's Avatar
    Yh did that, no luck. Ended up factory reseting which fixed it straight away. Thought I could just live with it but was annoying me. That's now 5 times I have had to set up my phone in 7 days due to issues, exchanging defect device etc.
    05-14-2015 07:58 AM
  1. Just before I send my phone of for repair - Battery Question
    By Villordsutch in forum Samsung Galaxy S4 Mini
    Last Post: 07-25-2015, 07:41 PM
  2. How can I get my alarm clock working?
    By Arcadia Blue in forum General Help and How To
    Last Post: 05-14-2015, 06:47 PM
  3. Replies: 1
    Last Post: 05-13-2015, 03:31 PM
  4. How to get a PDF showing on the screen?
    By jc1742 in forum HTC One M8
    Last Post: 05-13-2015, 08:19 AM
  5. Why am I unable to update my Galaxy Note 3 SM N9005 to Lollipop?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 05-13-2015, 08:16 AM
