1. KelseyRo4's Avatar
    My verizon galaxy s6 phone yesterday had 40% cell standby usage when the battery had been used for 7 hours. Ths phone died less than an hour later. As recommended on other forums, I did the wipe cache and then turned on advanced calling, and today the cell standby is on 7% after 7 hours. So, it's definitely better. My question is... generally, how much battery should cell standby use?
    05-13-2015 01:06 PM
  1. Replies: 1
    Last Post: 05-14-2015, 03:02 AM
  2. How do I change the font size back to normal on texts?
    Last Post: 05-13-2015, 03:10 PM
  3. Replies: 0
    Last Post: 05-13-2015, 12:51 PM
  4. Can't get emoticons to work?
    Last Post: 05-13-2015, 12:25 PM
  5. How do I reinstall assertive light on S4 Active?
    By Bob Call in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-13-2015, 11:54 AM
