1. AC Question's Avatar
    Won't charge at all lightning bolt appears as well as zero percent help
    05-13-2015 04:09 PM
  2. Gator352's Avatar
    Turn it off and try to charge it that way. If not, do a hard reboot by holding the volume up button, home button, both together and hold. Then press and hold the power button till it reboots.
    05-13-2015 06:19 PM
  3. droidguy1964's Avatar
    The condition that he's describing means the phone is already off. Just leave it plugged in for a while and you will be fine.
    05-13-2015 08:16 PM
  4. Gator352's Avatar
    Maybe so. I don't charge when it's off.
    05-13-2015 08:56 PM
  1. How hard is it to replace the battery in an N4?
    By Zenith49 in forum Google Nexus 4
    Last Post: 05-31-2015, 04:08 AM
  2. Qi charging speed?
    By jaums in forum Ask a Question
    Last Post: 05-21-2015, 01:41 AM
  3. Does the Droid Turbo Fast Charging require a special charger?
    By jaums in forum Motorola Droid Turbo
    Last Post: 05-14-2015, 02:16 PM
  4. when i try to enter a number emails pop up
    Last Post: 05-13-2015, 03:42 PM
  5. Why isn't my Galaxy S3 %100 charged?
    Last Post: 05-13-2015, 03:37 PM
