1. Amin Suleman's Avatar
    Hello All... I need your help!
    Loving my new S6... she's sweet! BUT, i cant dismiss the notification of "SIM card is not from Verizon Wireless". The phone works perfectly fine and is unlocked and I'm using a Digicel Sim (Caribbean Carrier) but i cant get rid of the notification.
    Any thoughts or insight appreciated. I have attached some screenshots
    Attached Thumbnails Unlocked SM-G920V -  unclear-able notification SIM card is not from Verizon Wireless How can I fix this?-screenshot_2015-05-15-11-49-46.jpg   Unlocked SM-G920V -  unclear-able notification SIM card is not from Verizon Wireless How can I fix this?-screenshot_2015-05-15-11-49-36.jpg
    05-15-2015 10:56 AM
  2. titans30dude's Avatar
    I think you need to be rooted to get that notification away.
    05-15-2015 04:02 PM
  3. dpham00's Avatar
    Yeah you need root, which is available for it.
    Sent from my Pearly White Verizon Samsung Galaxy S6 Edge
    05-16-2015 01:02 AM
  4. ib Themes's Avatar
    If you use android Lollipop here is the way to do it.
    Go to settings >> applications >> application manager >> all
    Then find an application called "activation agent".
    Click on it, then click force stop.
    skeeter9992 likes this.
    05-21-2015 04:14 PM
  5. EvoGraphx's Avatar
    Thanks, that worked, Now only issue is sending mms, I have galaxy SM-G920V, thanks in advance !!!
    05-22-2015 01:31 AM
  6. bob13bob's Avatar
    i think that only works until next rebate. disable is grayed out. only can force stop.
    08-12-2015 01:38 PM
  7. Beatriz Rosa's Avatar
    Just force stop the activation agent app, works until you reboot
    08-16-2015 07:27 AM
  8. justnivek's Avatar
    Force stop "Activation Agent" like said above, for MMS to work Google your carriers APN and follow EXACTLY.
    08-16-2015 11:54 AM
  1. Why are my 4G, 4G LTE connections slow or not connecting?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 09-29-2015, 01:16 AM
  2. Why is my AC Play Newstand not updating?
    By Straitbravesfan in forum Ask a Question
    Last Post: 05-15-2015, 11:29 AM
  3. facebook notifications
    By Courtnee Wallace in forum Samsung Galaxy Note 4
    Last Post: 05-15-2015, 11:05 AM
  4. HTC M8 Lost Scribble notes from my phone
    Last Post: 05-15-2015, 10:32 AM
  5. Replies: 1
    Last Post: 05-15-2015, 10:18 AM
