1. precon22's Avatar
    So I was reading anandtechs review on the galaxy s6 and I came across the display section if their review and had a chance to see a defect that I just found out i have, not it only shows up in very bright light, outside mainly but its there, see the picture below I was curious if anyone else has this, my other s6 also has this issue as well wanted to know if its widespread. Here is the link to it as well Display - The Samsung Galaxy S6 and S6 edge Review
    05-15-2015 03:35 PM
  2. SpookDroid's Avatar
    More than a defect, it's an inherent 'flaw' of AMOLED displays. Some black pixels are darker than others. And yes, it should only be apparent if you look at it under direct lighting but shouldn't make a difference when actually displaying an image. If it bothers you (and since this is a new phone) you can try to get it exchanged, but not sure if they'd do since this isn't a defect per se.
    precon22 likes this.
    05-15-2015 03:44 PM
  3. precon22's Avatar
    Well my replacement one did it as well so I'm just gonna deal
    05-15-2015 03:59 PM
  4. Chris778811's Avatar
    I have had 3 and they all do it. It happen when the screen gets extra bright under direct sun light. When it first happen I was like this sucks but you can really on,y see it on white screens, either way it still sucks that it happens at all...
    05-16-2015 12:33 AM
  5. precon22's Avatar
    Well my new one does it but very faintly almost not at all, not as detailed as my previous ones. But sad I had to send back my replacement replacement s6 because the home button was very bad and rattled and loose
    05-17-2015 02:14 PM
  1. Replies: 1
    Last Post: 06-18-2015, 09:25 PM
  2. Replies: 1
    Last Post: 05-16-2015, 01:21 AM
  3. Replies: 1
    Last Post: 05-15-2015, 09:00 AM
  4. Battery life problems fixed (Verizon, Lollipop)
    By Avgvstvs in forum Samsung Galaxy S4
    Last Post: 05-15-2015, 07:52 AM
