1. DrWu's Avatar
    Since I got the phone bluetooth has been terible, failing to auto connect much of the time with 2 different cars and my zenwatch. Only work around I've found is to go to the Bluetooth application in app manager and clear data. After I do that I will get reliable connections for anywhere from a few hours to a couple of days and then it goes kaput again. It's very frustrating. Do I have a bad phone or is anyone else having similar issues? I have the Verizon variant.
    Thanks!
    05-16-2015 10:44 PM
  2. Golfdriver97's Avatar
    I am not aware of any problems, but I can be wrong.
    Have you talked with either Samsung or Verizon, in case this is a malfunction to be covered under warranty?
    05-16-2015 11:53 PM
  3. Mike Oakley's Avatar
    My wife has a GS6 and has problems from time to time connecting to her Ford Sync and her Asus Zenwatch. Connects, disconnects. Frustating.
    06-11-2015 12:45 PM
  1. Replies: 8
    Last Post: 05-17-2015, 07:36 PM
  2. Problems rooting SM-N910F!!
    By Asmir Puhovac in forum Samsung Galaxy Note 4
    Last Post: 05-17-2015, 05:58 PM
  3. Keyboard Problems
    By NerdSneeze in forum Ask a Question
    Last Post: 05-16-2015, 09:07 PM
  4. Can I get some help with Galaxy S5 print problems?
    By SilverLib176 in forum Samsung Galaxy S5
    Last Post: 05-16-2015, 08:00 PM
  5. Replies: 0
    Last Post: 05-16-2015, 07:01 PM
