HEY GUYS I HAVE FINNALY FOUND THE REAL FIX TO THIS PROBLEM. New to this FORUM btw, but I read it alot. I have the s6 Edge on Verizon and even though I'm showing full wifi signal and so was my wife's s5(she's on att&t) neither of us could barely get a page to load. I've done everything. Set manual channels. Disabled everything you can think of that might cause it on the phone. Disabled ipv6 in the router settings. Factory reset. Cache clean. Anything you can think of I've done it. Even tried to manually change the DNS to Google or something else. That didn't work but DNS IS THE PROBLEM. There's a problem with lollipop and DNS. And they are probably going to send an update eventually to fix it but I wasn't about to wait and I know my wife's s5 wouldn't get it.
So I was ready to return it. Anyway out if nowhere I found THE SOLUTION AND THE APP THAT FIXES IT IMMEDIATELY TODAY. Go to the to the play store and download DNS SET. Forget your connection and re enter your WiFi password. Then open the DNSet app and check off auto run. Then hit the run button. INSTANT FIX! I SWEAR TO GOD. You have no idea how happy I was to see this work. I stopped a it and reopened it many times to see if it would always work and it does. Instant loads. Super fast speed. Christ I was outside of my house and even there everything was loading instantly like it should. YouTube instantaneous. Anything. It fixes the problem. Believe me I went through this and it works and it takes 5 mins to do it at most. It's was a life savor. Don't return your phone or get frustrated and say screw it. This works and I couldn't wait to frigging share it with everyone because I know how can frustrating it is. I was about to return my s6 edge today. Swear to God. The only thing it didn't work in was my friends s5 today on sprint and I don't know why. Something to do with sprint maybe. But it definitely works with verizon and attt.
JUST A HEADS UP, I did leave the ipV6 disabled on my router and I still have WiFi direct disabled on my phone because I was afraid to change anything after this worked. Might have nothing to do with it but if for some crazy reason this app doesn't work, disable that and it will be fine. All my other settings on the router are normal. Auto channel and AES/TPIK are still on. Anyway This works and I was happy to help so I posted. Let me know of it works u for you guys. And spread the word so people aren't dealing with this [language removed]. It's not right. Let me know how you make out. Take care
