1. Philip Manwaring's Avatar
    I generally don't have trouble getting through a work day with my S6, but I do wonder whether the Android utilization is high. During a typical day (1 - 2 hours SOT, 14-15 hours off charger), I'm burning about 60%-70% of total battery, 30% of which is Android System (~22%) and Android Kernel (~8%).
    Google Play and other apps are all typically < 5%.
    Is this normal, or does this indicate that a factory reset might be a good idea? On previous phones I don't recall core Android being this high (usually <10%).
    Thanks for any input you may have.
    06-01-2015 10:57 AM
  2. warpdrive's Avatar
    While that is high, your SoT and thus usage is low. During times that I don't use my phone that much, I have seen it high on the list. I just don't remember how much it ate the battery.
    I wouldn't worrie that much about it.
    06-01-2015 11:33 AM
  3. Rukbat's Avatar
    If your phone is using nothing else but Android System+kernel, their battery use would be 100%. If you're running games that require a lot of CPU power, keep all the radios on all the time, have a weak cell signal and keep the screen turned up all the way all the time, Android System+kernel could be 10%.
    What percentage of total use is used by Android depends on what's being used by other things. 14-15 hours of use to 40% isn't anything to complain about, regardless of the percentages.
    06-02-2015 03:04 PM
  1. Replies: 3
    Last Post: 06-02-2015, 09:14 AM
  2. Help me pick out a phone under $75 for straight talk?
    By Redchigh in forum General Carrier Discussion
    Last Post: 06-01-2015, 07:25 PM
  3. Replies: 1
    Last Post: 06-01-2015, 11:22 AM
  4. Volume is stuck muted, how can I fix this?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 06-01-2015, 11:20 AM
  5. How do I get the back off of my phone to get the battery in?
    By AC Question in forum Hardware Hideaway
    Last Post: 06-01-2015, 10:52 AM
