1. ramsv94's Avatar
    Hello, i am trying to increase my battery life because it snot all that great right now. I'm only getting about 3 hours of screen on time. I was thinking about doing a factory reset, but wanted to try to fix it before i go through that. Looking at my GSAM battery stats, my WIFI Active is just as high as my screen usage. Both are at over 30%. Having Wifi use that much of my battery doesn't seem right to me. Also Its a sprint GS6, any Ideas?
    Thanks
    06-10-2015 04:14 PM
  2. srkmagnus's Avatar
    Thanks
    I don't think WiFi is the actual problem. Can you post a screen shot of the battery usage screen along with the page that gives you more detailed information about the highest app/service?
    Hopefully we can find the problem (if there really is a problem) and save you from a reset.
    06-10-2015 05:03 PM
  3. Kalvin Kerns's Avatar
    Thanks
    I believe it's standby time while on wifi that's causing the drain. If I'm not mistaken it's a known bug with Lollipop.
    But I agree it doesn't make sense for the battery life to be WORST on Wi-Fi, if anything it should be better.
    06-10-2015 05:11 PM
  4. ramsv94's Avatar
    i just happened to charge it.
    Attached Thumbnails WiFi killing battery?-screenshot_2015-06-10-15-27-34.jpg   WiFi killing battery?-screenshot_2015-06-10-15-27-40.jpg
    06-10-2015 05:36 PM
  5. razza1987's Avatar
    That is so weird. My Wi-Fi active is around the 13% mark on my phone
    06-10-2015 05:39 PM
  6. almawhite's Avatar
    my wifi is working perfectly fine. doesn't drain that much.. consistent
    06-10-2015 05:48 PM
  7. tgs3838's Avatar
    I haven't really tested it. Usually im only on wifi at the house. So im not really using it all that much while at home. But i have also noticed that it seems to die faster when its on wifi than just using regular Data. But maybe im just crazy.
    06-10-2015 10:12 PM
  8. KelseyRo4's Avatar
    WiFi takes a big chunk of my battery too. I leave it off unless I'm using it at the moment
    06-11-2015 05:20 AM
  9. jcp007's Avatar
    Having great coverage area and unlimited data with AT&T, I use Wifi only when absolutely necessary but I turn it off when not it use. I would think being in a high traffic area or having reception issues within your own home would cause a bit of drain on the battery.
    06-11-2015 06:36 AM
  10. cwise222's Avatar
    My WiFi usage will range anywhere between 15%-35%. I am pretty sure it's a Lollipop bug, my M8 did the same thing when it got bumped to Lollipop.
    06-11-2015 07:53 AM
  11. atkjhi's Avatar
    WiFi is the silent killer. My battery life doubled when I stopped using the WiFi connection at work. If you're a heavy data user with data limits you may need to use WiFi but if you don't have to use WiFi don't use it.
    drone3 likes this.
    07-11-2015 04:15 PM
  12. jdhooghe's Avatar
    Sorry, I just got this phone: is this a bug with Android? Should I have my tasker app turn off wifi when I shut off the phone? Thank you
    07-11-2015 07:18 PM
  13. bbtkd's Avatar
    I like the app Wi-fi Matic. When you connect to a new Wifi, it starts scanning which cell towers are in the vicinity. Then after a minute or so, you stop it from scanning. From then on, when you are near one of the cell towers associated with a known Wifi, it turns Wifi on. When you leave the vicinity it tuns Wifi off. This has helped me avoid having to turn Wifi off when at work since we're not allowed to connect our personal devices.
    Also be sure you go into settings/wifi/more/advanced and disable "Always allow scanning". This is a feature where the OS can enable wifi periodically to try to use it for location, presumably when GPS and tower location finding is not viable. I've noted significant reduction in battery drain since disabling this.
    07-11-2015 08:14 PM
  14. jdhooghe's Avatar
    So I disabled WiFi when the phone has its screen off using tasker and I'm no longer getting the cell standbye. Hmm
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    07-11-2015 11:06 PM
  15. atkjhi's Avatar
    It's weird, cell uses a ton of battery when it's standing by, and uses far less battery when it's not standing by. Unless there is some kind of reporting bug with Android and the battery stats are not correct.
    Maybe cell standby is actually WiFi radio usage and that's what it should be called?
    07-12-2015 12:33 AM
  16. msavic6's Avatar
    There is currently a bug with GSAM that mis-represents the actual percentage of battery used by WiFi.
    In order to rectify this.
    - Open GSAM
    - Go into Preferences
    - Scroll down to Device Power Profiles
    - Enable Custom Profile
    - Edit Profile
    - Change the value for WiFi Active to 767.
    - Save and you're done.
    GSAM will now correctly display the battery percentage associated with WiFi Usage.
    acles003 likes this.
    07-12-2015 02:33 AM
  17. atkjhi's Avatar
    What is GSAM? Does your phone have to be rooted to access?
    So I was right, cell standby is actually measuring WiFi radio usage.
    07-12-2015 03:24 AM
  18. atkjhi's Avatar
    Never mind I figured it out, it's a separate app. I'll try it out. Thanks
    07-12-2015 03:37 AM
  1. How can I fix a random battery drain on S5 with 5.0.?
    By jgusa in forum Samsung Galaxy S5
    Last Post: 06-12-2015, 08:55 AM
  2. Why aren't my apps working when connected to WiFi?
    By AC Question in forum Android Apps
    Last Post: 06-10-2015, 06:40 PM
  3. Android phone not picking up Wifi while laptop will
    Last Post: 06-10-2015, 06:23 PM
  4. What is up with my Galaxy S5 battery life?
    By Robert_Killam in forum Ask a Question
    Last Post: 06-10-2015, 01:46 PM
