I can't speak for the case that you are looking at but I do have a suggestion on something that you might like.
www.seidioonline.com/mobile/Product.aspx?ProductCode=CST2SSGS6K-BK
While I use plenty of different cases on my phones, the dilex or what is now called the dilex pro is the case that I always use when I need maximum protection but don't want the bulk. I have dropped countless phones plenty of times using such cases both outside on concrete and inside on hardwood floors (ok, it's my cat that knocks them off my table all the time as I almost never drop my phones) and I've never had even a broken screen. They are rugged and tough while not being bulky... And have a kick stand too. (oh, this company was basically the first to have kick stands, and they are far better then the competition) It also comes in many colors. I typically also use a holster that they make for it so it protects the screen better than being in your pocket and frees up my pockets for other things. (I typically don't use screen protectors on my phones)
Again, I use plenty of cases as I'm a geek and like to change things up allot, especially if I'm mostly indoors and not working a manual labor job or on some adventure. But if I am doing some crazy stuff or some labor intensive work, this case is what I use each and every time.
If I had to choose just one case for my phone, it's this one always.
