1. fareastpanda's Avatar
    The menu folders button seems to appear the only light to be lit and not the back button. I was wondering if I could fix this or not, I can't really open the phone so... Does any one know to fix this?
    This was probably when I dropped it in the sink but only minimal amount of water touched it, please help if you guys know!
    06-29-2015 08:43 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That's the Recent Apps button. Fixing that would require someone to open the phone up. If there has been water exposure, there is probably a water exposure indicator inside the phone that would be positive, so chances are that warranty wouldn't cover it.
    fareastpanda likes this.
    06-29-2015 08:46 PM
  3. jcp007's Avatar
    Insurance claim?
    06-29-2015 09:51 PM
  4. fareastpanda's Avatar
    Ahhh, hmm... So I can't fix this on my own? And would it be claimed to be damaged if I have the NEXT plan on my carrier?
    06-29-2015 10:12 PM
  5. fareastpanda's Avatar
    Insurance claim?
    Don't got insurance... ):
    06-29-2015 10:12 PM
  6. B. Diddy's Avatar
    I'm not sure about how the Next plan would be affected--there's probably something in the fine print addressing it.
    Who knows, maybe the water exposure sticker is negative, and this wasn't related to the moisture. You could always try to get it repaired under warranty--or see if the store will give you a replacement.
    06-29-2015 10:14 PM
  7. catiron's Avatar
    I have a one week old galaxy s6. The Recent Apps key illuminates and works fine. The Back Key works functionally, but it does not illuminate. I have had no water damage or drops of any kind. My research suggests it's a hardware problem. Have you seen this before? Is there a fix?
    08-03-2015 09:31 PM
  1. Replies: 1
    Last Post: 06-29-2015, 09:10 PM
  2. Wifi problems Samsung 3?
    Last Post: 06-29-2015, 08:51 PM
  3. Only one touch key light being lit on Samsung Galaxy S6
    By fareastpanda in forum Ask a Question
    Last Post: 06-29-2015, 08:47 PM
  4. AT&T Samsung S5 data problems
    Last Post: 06-29-2015, 12:42 PM
  5. Replies: 1
    Last Post: 06-29-2015, 11:48 AM
