1. Keith Wardlow's Avatar
    I have the Samsung Wireless charging pad, could I use the Fast Charging Adapter with it, or should I stick the the wall Adapter it came with? Would it make a difference in charging speed, or would the fast charging Adapter not work like its supposed with the the chargig pad? For some reason when I am plugging in my micro usb cable into my phone, it seems does not go in smoothly
    06-30-2015 08:57 PM
  2. kb31's Avatar
    Won't matter. It'll only use what it can and fast charge doesn't work with wireless charging. Just make sure you use at least a 2 amp charger.
    Sent from my SM-G925V using Tapatalk
    06-30-2015 08:59 PM
  3. MHBlink8's Avatar
    You can use the fast charger with your charging pad, but it won't charge your phone any faster than one that came with the charging pad. Right now Qi doesn't support quick charge.
    06-30-2015 09:01 PM
  4. Keith Wardlow's Avatar
    I wish it did, would have been nice
    06-30-2015 09:15 PM
  5. jcp007's Avatar
    There should no issue with it. The device will be fine and you will,probably have upgraded by the time it would have even been an issue. It makes little sense for Samsung to provide a rapid charger if it is going to damage your device.
    07-01-2015 06:31 AM
  6. jerryrip's Avatar
    I just use the wireless charging pad with the adapter it came with for regular charging, or just plug in the cable that came with the phone for quick charging.
    07-06-2015 01:12 AM
  1. so, does the screen need to be off or not?? (quick charging)
    By hunter777 in forum Samsung Galaxy S6
    Last Post: 07-07-2015, 03:39 AM
  2. Simple stupid question
    By Candice Johnson1 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 07-01-2015, 05:21 AM
  3. Multi window question
    By droidntn in forum Samsung Galaxy Note 4
    Last Post: 06-30-2015, 07:29 PM
  4. Nova Launcher Question
    By Soapm in forum Wallpapers, Ringtones, and Themes
    Last Post: 06-30-2015, 02:43 PM
  5. My Samsung Note 3 is dead and won't charge up, why?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 06-30-2015, 01:20 PM
