1. mcefalu's Avatar
    I have an S6, KIndle Fire HDX, and Acer Chromebook. All are sitting side-by-side about 3 feet from the wireless connection point (Xfinity). My Chrome book has 5 bars, my Kindle Fire has 5 bars, but the S6 has 2 bars. I can start a download on the S6 and the Kindle Fire at the same time and the Kindle Fire downloads much faster. Are there some settings that I should check to make sure the S6 is set up correctly? Is there a reason why it would not get as good a connection to the wireless?
    Thanks, as always, for your help.
    07-02-2015 04:07 PM
  2. oscarnyc's Avatar
    I would expect a chromebook or tablet to have better wifi receivers than a phone. IIRC, Amazon specifically touted the quality of the wifi receiver in the HDX when it was announced.
    mcefalu likes this.
    07-02-2015 07:34 PM
  3. dronebott's Avatar
    Too add to that, I've found wiping the cache partitioning and reflashing the device has been an easy fix to most problems, such as connection
    07-02-2015 11:31 PM
  4. wrecklass's Avatar
    Also bear in mind several devices close together can interfere with each other.
    Should there be smoke coming out of my cpu?
    mcefalu likes this.
    07-03-2015 12:01 AM
  5. mcefalu's Avatar
    Thanks...I didn't think of it that way. Makes sense.
    07-03-2015 10:41 PM
  1. Why aren't my homebutton and touchkeys working on my Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 10-27-2015, 07:20 PM
  2. How do you back up data from the Galaxy S6 phone?
    Last Post: 07-02-2015, 11:44 PM
  3. lost App.icon on home screen
    By 420benz in forum Samsung Galaxy Note 4
    Last Post: 07-02-2015, 06:22 PM
  4. how to reset phone if won't power on?
    Last Post: 07-02-2015, 04:08 PM
  5. Why do I have such terrible call quality on my Samsung Galaxy S6?
    Last Post: 07-02-2015, 02:55 PM
