Hi everyone. I was just wondering how many people on this forum are on the Telstra network in Australia and if so how many of you are experiencing problems with the cell signal
A weak signal really tells you just one thing - that you chose the wrong carrier (unless there's no carrier with good coverage where you are). that's the first thing you should so when deciding on a cellphone and plan - check to see which carrier has a strong signal where you need a signal. Choose from one that does. Then you can choose plans, phones, etc.
The best free unlimited everything plan on the best cellphone ever made is worthless if there's no signal where you are.
Telstra is the most expensive company in Australia for a reason. It has double the amount of reception areas than any other company in this country
