1. Blazer's Avatar
    I just purchased an Ivation 3-coil Wireless Charger from Amazon.
    http://www.amazon.com/Ivation-Wirele...cUvbUpU4536661
    This looks identical (except for the logo) to the Qi-Infinity model that sells for $20 more.
    This folding and "angle adjustable" wireless charger does not come with an actual power adapter. It comes with USB 2.0 cables and you use your own charger. (I have several) The manual simply says to plug it into your own power adapter or the USB port on you laptop of PC. No mention is made of optimal power adapter size. My question concerns the amperage rating of power adapters and what would be optimum for this charger. The specs simply show: INPUT: DC5V, 1500mA. Could a 5V power adapter with too low or too high amperage be a problem? is higher better?
    07-05-2015 02:37 PM
  2. itguyjax8430's Avatar
    http://www.amazon.com/Ivation-Wirele...cUvbUpU4541758
    Welcome to Android Central!
    I would think the 5V one should be fine.
    07-08-2015 07:58 AM
  1. Question and keyboard and the edgo
    By Fred Wilson2 in forum Samsung Galaxy S6 edge
    Last Post: 07-08-2015, 08:46 AM
  2. Replies: 1
    Last Post: 07-08-2015, 07:06 AM
  3. New S6 Edge 64GB Black , Verizon - questions
    By Knuckle66 in forum Samsung Galaxy S6 edge
    Last Post: 07-07-2015, 12:10 PM
  4. Question regarding securing SMS with dual sim
    By Dennis087 in forum ASUS ZenFone 2
    Last Post: 07-05-2015, 10:29 AM
