1. Ray3613's Avatar
    I just bought a new wireless charger. The round one by Samsung. My charge was at 15%. I kept for charging nd at that time it showed around 2 hrs nd 15 mins. Aftr min or two the charging time changes to 4 hours.... Tried keeping it back again, the same thing happened aftr a min! Have anyone got any idea what to do?
    07-20-2015 10:34 AM
  2. the tall guy's Avatar
    The wireless charger won't charge your phone at the same speed as the fast charger will. Usually when I put my phone on my wireless charger at night, I have about 30% left on charge and it takes about 4 hours to get to 100%.
    If you are looking to charge it quicker, I would suggest using the fast charger that came with the phone.
    07-20-2015 10:38 AM
  3. Ray3613's Avatar
    Ohh so it's common, thts a relief. It actually showed about 2 hrs nd 14 minutes at starting nd initially changed to 4 hours. Thts wt worried me. All's good. Thanks.
    07-20-2015 10:50 AM
  4. Gator352's Avatar
    What? I'm using a choe charger and mine goes from 30% to 100% in about 2 to 2 1/2 hours.
    07-20-2015 11:10 AM
  5. Ray3613's Avatar
    I'm using the samsungs round qi charger. It charges fast if the phone is off. But nt tht fast if it's on nd idle! Is it common for every Samsung qi chargers or just mine? Says around 4 hours at 15%
    07-20-2015 12:20 PM
  6. krazyatom's Avatar
    Can I use Nokia dt900 wireless charger for my s6?
    Sent from my iPhone using Tapatalk
    07-20-2015 12:30 PM
  7. Ray3613's Avatar
    Yeah your s6 supports most qi standards. Try it.
    krazyatom likes this.
    07-20-2015 12:31 PM
  8. Ray3613's Avatar
    It charges better now 2 hrs 20 min rate from 20%. I'm good to go.
    07-20-2015 12:45 PM
  9. the tall guy's Avatar
    That's quite good. Yeah usually my phone takes between 3 - 4 hours to fully charge. Doesn't bother me as I'm sleeping at the time
    07-20-2015 01:59 PM
  10. Gator352's Avatar
    Yeah same here. Even if it took 3 or 4 hours, it wouldn't matter. I'm sleeping!
    the tall guy likes this.
    07-20-2015 05:00 PM
  11. Ray3613's Avatar
    Haha I'm nt an isomaniac but I do charge at other times too. ND 4 hours a lot for me.
    07-20-2015 06:11 PM
  12. Bassbiker's Avatar
    The square Samsung Qi charger is pure crap.
    07-20-2015 06:49 PM
  13. 8taylor8's Avatar
    Does it make a difference on how you charger your phone from fast charger, wireless charger or even car charger, on the battery life of the phone?
    Posted via the GS6
    07-25-2015 01:44 PM
  14. Gator352's Avatar
    Posted via the GS6
    Well, they say to slow charge lithium ion batteries so fast charging is bad. Wireless charging creates heat and heat is bad for batteries. So that leaves slow charging your best bet. Me personally, i use wireless and fast charging when ever i can.
    07-25-2015 08:07 PM
  15. felloffthetruck's Avatar
    Do different wireless charger make the S6 get hotter ?
    I have the TYLT solo charger and I believe the phone gets hotter on it then on the stock Samsung wireless charging pad.
    07-25-2015 08:54 PM
  16. hiterus's Avatar
    My practice is to put the phone on airplane mode and toggle back the wifi connection. It will be faster and less hotter.
    But still, I prefer cable charger
    07-25-2015 09:57 PM
  17. bbtkd's Avatar
    I believe the Qi standard is 1A charge rate using a 2A source for input (usually AC adapter). If you use a small mah rated source, it will charge correspondingly slower. I don't believe any chargers break that 1A limit. The faster you charge, the more it heats the battery. At some point, you could rupture the cell and you will have a fire when the Lithium meets air. Or, when the battery heats it can bulge and destroy your phone, or heat damage adjacent components. The S6 Edge reportedly has an issue where the rapid charger leads to the battery cooking the accelerometer chip.
    07-25-2015 11:11 PM
  1. Disable full charge notification
    By vapore0n in forum LG G4
    Last Post: 11-14-2016, 05:50 PM
  2. Replies: 4
    Last Post: 07-21-2015, 08:45 AM
  3. Can I get some help with some SCL23 issues?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 07-20-2015, 01:46 PM
  4. Home Button Keeps Clicking and Battery Issue.
    By Dillz97 in forum Samsung Galaxy S4 Mini
    Last Post: 07-20-2015, 12:47 PM
  5. Replies: 1
    Last Post: 07-20-2015, 10:40 AM
