A andtest New member Jul 27, 2015 4 0 0 Visit site Jul 27, 2015 #1 Hello! Today I noticed that I can't change the sync settings of my google account. Does anyone know how to fix it? Thank you!
Almeuit Moderator Team Leader Moderator Apr 17, 2012 32,277 23 0 Visit site Jul 27, 2015 #2 Did you happen to turn off background data within your "Data Usage" area on the phone?
A andtest New member Jul 27, 2015 4 0 0 Visit site Jul 27, 2015 #3 I didn't change anything in data usage. Maybe removal (and recreating) of the account will help?
Almeuit Moderator Team Leader Moderator Apr 17, 2012 32,277 23 0 Visit site Jul 27, 2015 #4 andtest said: I didn't change anything in data usage. Maybe removal (and recreating) of the account will help? Click to expand... I would try that -- That definitely is something I haven't seen before haha.
A andtest New member Jul 27, 2015 4 0 0 Visit site Jul 27, 2015 #5 Tried that, it doesn't work. And now I have all these options turned on If I do factory reset what data will be lost, can it help?
A AlphaTango414 Well-known member Jan 13, 2011 3,939 95 0 Visit site Jul 27, 2015 #6 Everything that is not backed up will be lost. After a factory reset, it will come be like turning it on the first time coming out of the box. I've never seen this either yet. I'm curious to what has caused this issue tho for sure. Sent from my SAMSUNG-SM-G920A using Tapatalk
A andtest New member Jul 27, 2015 4 0 0 Visit site Jul 27, 2015 #7 I still think about a factory reset. I have a s6 edge without a bank card and sim (just bought it), may it be because of this? UPD: I could change the settings before. UPD2: I did factory reset, the problem is solved. Thank you all! Last edited: Jul 28, 2015
