1. cafshari's Avatar
    Hi,
    Just got a Galaxy S6. I want to be able to use the volume buttons to control Ringtone AND Notifications (and System volume if possible) all by pressing Volume Up or Down side buttons.
    If my ringtone is up high, then I always want my notifications up high. Essentially I want their volume synced always. If I'm lowering my ringtone volume, I want to lower all other volumes as well (besides Media, I understand that that should be controlled separately).
    I guess it's cool that you can control Ringtone & Notification volumes separately, but for me personally it creates an inconvenience. I want them both at the same volume always, without having to adjust them both individually.
    Is this possible? Thanks in advance
    07-29-2015 04:01 PM
  1. Replies: 7
    Last Post: 07-20-2016, 08:05 PM
  2. Are you still happy with the g4?
    By mach1man in forum LG G4
    Last Post: 07-06-2016, 02:24 PM
  3. Replies: 3
    Last Post: 08-01-2015, 11:55 AM
  4. Replies: 1
    Last Post: 07-29-2015, 04:03 PM
  5. Replies: 0
    Last Post: 07-29-2015, 03:41 PM
