1. AC Question's Avatar
    I accidentally dipped my phone in water but I had the case on. (Otter Box).
    I don't know what to do.
    08-24-2015 09:09 PM
  2. Rukbat's Avatar
    Otterbox isn't a waterproof case. (You can probably drive over it, though - I wouldn't do without mine.) You probably damaged the speaker a bit. Either keep the volume off max or have the speaker replaced.
    08-25-2015 12:47 AM
  1. Replies: 4
    Last Post: 01-13-2016, 09:27 AM
  2. How do you download games on your sd card
    Last Post: 08-25-2015, 12:50 AM
  3. My calls are ending prematurely, how do I stop it?
    Last Post: 08-25-2015, 12:49 AM
  4. My LG G4 will not stop restarting.
    Last Post: 08-24-2015, 10:31 PM
  5. Transferred Bionic Videos Won't Play On PC
    By bionic777 in forum Droid Bionic
    Last Post: 08-24-2015, 08:35 PM
