08-27-2015 08:54 PM
26 12
tools
  1. sepandee's Avatar
    I'm starting to really regret getting an S6. My friend and I were shopping for a phone in April and we had the whole iphone vs android/samsung debate. Now I wish I had listened to him. I just want a damn phone that freaking lasts from morning to night, not just for 8 hours.
    Phew. Excuse the rant.
    My S6 is 4 months old. I'm relatively active on it but mostly for some light browsing, whatsapp, email, and BBC news once in a while. I've disabled all the non-google apps that came with the phone that I couldn't delete. Location is sometimes on, sometimes off, but it doesn't make a huge difference if I'm active on my phone. Screen brightness is automatic but always at the lowest automatic setting. Bluetooth off.
    Here are some screenshots. Please ignore the Tinder
    Oh, and sometimes the phone gets really, really hot, like when I'm using the aforementioned app.
    Would appreciate any help I can get.
    Attached Thumbnails Galaxy S6 Frustrating battery life and overheating-7.jpg   Galaxy S6 Frustrating battery life and overheating-6.jpg   Galaxy S6 Frustrating battery life and overheating-5.jpg   Galaxy S6 Frustrating battery life and overheating-4.jpg   Galaxy S6 Frustrating battery life and overheating-3.jpg
    Galaxy S6 Frustrating battery life and overheating-2.jpg   Galaxy S6 Frustrating battery life and overheating-1.jpg
    08-25-2015 09:35 AM
  2. tstolz's Avatar
    Wow, I have yet to get 12 hours on one charge. I'm beginning to think it's a T-Mobile coverage issue in New Orleans for me.
    08-25-2015 10:08 AM
  3. moonoverparma00's Avatar
    The S6 battery life is pretty bad all around. I can't wait to trade mine in.
    08-25-2015 11:08 AM
  4. sepandee's Avatar
    So resignation is the solution?
    08-25-2015 11:27 AM
  5. AhmedAdd's Avatar
    my Galaxy S6's battery is pretty good.
    Galaxy S6 Frustrating battery life and overheating-screenshot_2015-08-24-19-59-18.jpg
    Galaxy S6 Frustrating battery life and overheating-screenshot_2015-08-24-19-59-22.jpg
    Galaxy S6 Frustrating battery life and overheating-screenshot_2015-08-24-19-59-26.jpg
    08-25-2015 12:09 PM
  6. Saros's Avatar
    If you're not using Google apps like Hangouts, Google Play Music, etc., disable them also. Do you use OneNote at all, or SmartRemote? If not, disable them as well.
    Bluetooth off.
    Your screenshots show Bluetooth is on and has been for the duration of your cycle.
    Also, for the love of Android, please uninstall Clean Master immediately.
    08-25-2015 01:02 PM
  7. razza1987's Avatar
    I just disabled hangouts and smart remote as I never use them. Is there a benefit to disabling apps that show up as 0% under battery usage?
    08-25-2015 01:14 PM
  8. Saros's Avatar
    Individually they may not consume much in the way of battery or system resources, but when there are multiple, preloaded apps you never use, there's no point letting them run in the background as they can have a cumulative effect. For anyone trying to maximize usage, every little bit helps.
    08-25-2015 01:32 PM
  9. cwise222's Avatar
    What are the sync settings for your Google account? If you have everything set to on and syncing then that will cause battery life to take a hit. Anything you don't use (like Google Play Music, etc) you will want to turn off the sync and disable the app because it will still sync and sync and sync even if you've never opened the app. Even if you disable able the application it will still, somehow, show as syncing unless you turn off the sync. That kind of stuff get wrapped up into Google Play Services and Android System and other things in the battery listings so it is not always obvious. If you also have Location History turned on that does drain the battery as well.
    If you have location settings to to High (uses GPS, Wifi and call to determine location) then that could cause apps the use locations to make the phone run hot. Unless the phone outright tells you that it is overheating or shuts itself down, etc, then it really isn't overheating in a way that will harm the phone. In most, normal, circumstances phones act like computers when it comes to heat. The will shut themselves down or throttle back before any damage is done.
    Saros likes this.
    08-25-2015 02:19 PM
  10. sepandee's Avatar
    How? Hoooooooooow? Why isn't mine like that?
    I use play music, but I disabled Hangouts and OneNote. But these accounted only for 0.0%-1% of battery usage.
    08-25-2015 02:45 PM
  11. sepandee's Avatar
    By overheating I meant heating: it's hot--hot enough that holding it against my cheek or in my hands become very uncomfortable.
    As for sync, I have app data, calendar, chrome, contacts, gmail, photos, photos backup, and People details on. I think that's reasonable and doesn't consume that much battery.
    This is what pisses me off. As much as I kept arguing that iPhones suck and blah blah blah, the thing just works. Sure, you can't do this and that with it and it forces you to do this and that, but for crying out loud, 90% of us just want a phone that runs a few apps and can last for a day, without having to tweak every little detail inside our phones. Is that too much to ask?
    08-25-2015 02:53 PM
  12. Saros's Avatar
    Yes the individual usage appears small but if there are lots of preloaded apps running which you never use (and especially if they're trying to sync, as cwise222 noted above), they're going to chip away at your potential for longevity. Turn Bluetooth off when you don't need it. Only use high-accuracy location settings if you really need to enable GPS.
    I cannot emphasize enough that Clean Master is a terrible choice and should be removed. Avoid using "battery saver" or "task killer" apps, or anything that monkeys with Android system operation & RAM management. They invariably do more harm than good, waste resources, degrade your performance, and eat up your battery. And some are just outright malicious.
    This last cycle has been light usage for me, not very different from what you described:
    That's off the charger for almost 36 hours, with 3h6m31s of screen-on time, and it had just dropped under 40% remaining before snapping the screenie.
    08-25-2015 03:31 PM
  13. sepandee's Avatar
    OK well I've also deleted Clean Master. I'm also disabling Location unless I need it, although I still think you should use a phone without having to turn things like Location On and Off and worry about battery. Let's see how it goes tomorrow after a full charge.
    08-25-2015 03:39 PM
  14. javitolopez's Avatar
    The solition off battery drine is Hard reset in 5.1 1 is 100% working
    Enviado desde mi SM-G920F mediante Tapatalk
    08-25-2015 04:08 PM
  15. Saros's Avatar
    On this cycle I posted, location was enabled the entire time, just on the power-saving setting (no GPS). It's unfortunately not just a matter of on/off, or what we intuitively think should be acceptable; real-world usage results depend on the level of resources it's using (Wi-Fi & mobile network vs GPS) and how dependent apps interact with it. (e.g.: A weather widget that uses GPS every 15 minutes to refresh conditions is going to add up over a day's use and detract from your battery's potential.)
    Since the quick settings panel is so easily accessible to toggle features on and off, it's sound practice to turn off services you aren't using and re-enable them as needed.
    08-25-2015 05:11 PM
  16. razza1987's Avatar
    Saros I would agree with you on all the taskmaster apps except for greenify. Greenify has made my standby time go through the roof.
    Also I have Bluetooth permanently switched off yet sometimes it shows up on gsam results as used. So weird
    08-25-2015 09:41 PM
  17. NewAndroidNoob's Avatar
    This is what I had to do after 5.1.1
    Only 1 day so far, but my battery life is back to normal.
    08-25-2015 11:59 PM
  18. D13H4RD2L1V3's Avatar
    I was gonna ask about Clean Master being there, but I see that you've removed it.
    Good man.
    08-26-2015 07:21 PM
  19. Anti the gamer's Avatar
    I personally would say turn off auto brightness. I keep my phone at about 40% and turn it up only when i need too. Also if you arent closing your apps that could be using more battery. If you have auto updates on that could drain your battery
    08-27-2015 01:05 AM
  20. Saros's Avatar
    Good man.
    I strongly suspect many of the complaints about the S6 (and other flagships, for that matter) would vanish if people were acquainted with the detrimental behavior of that and similar apps.
    08-27-2015 01:11 AM
  21. syspry's Avatar
    S6 owners here will obviously take a strong contrary stance to my advice but... yeah, this phone's battery life is an ongoing bone of contention. IF battery life is high priority for you I'd strongly advise selling it and getting a Note 5, Moto X PE, or wait for the soon to be launched Nexus phones. Xperia Z5, iPhone 6S+.
    08-27-2015 07:39 AM
  22. sepandee's Avatar
    I don't. I think that's good advice. Even when I didn't have Clean Master, my battery was still s**t. And if we have to do what Anti the Gamer suggests to preserve battery -- turning off auto brightness, auto update, etc. -- then it's a step in the wrong direction for Samsung.
    Anyways, I did a hard reset. We'll see how it holds up.
    08-27-2015 08:13 AM
  23. D13H4RD2L1V3's Avatar
    BTW, OP. When you mentioned "overheating", how is it like?
    Does it get too warm?
    Does it get warm when it's not supposed to?
    Does it get hot to the point where the phone throttles and warning messages about temperature start popping up?
    08-27-2015 08:34 AM
  24. sepandee's Avatar
    It gets hot when the phone's active. No warning messages--just to the point that even holding the phone against your cheek is very uncomfortable.
    08-27-2015 02:23 PM
  25. OriginalMrC's Avatar
    That's not normal. This is the one smart phone that for me never runs hot. I suspect you either have a rogue app which is constantly using juice or you have a battery issue.
    drone3 likes this.
    08-27-2015 06:35 PM
26 12
  1. Replies: 5
    Last Post: 08-25-2015, 11:49 AM
  2. Replies: 0
    Last Post: 08-25-2015, 09:21 AM
  3. samsung galaxy s 4
    Last Post: 08-25-2015, 09:00 AM
  4. Replies: 2
    Last Post: 08-25-2015, 08:57 AM
  5. How can i make a video call on samsung galaxy ace style
    Last Post: 08-25-2015, 08:43 AM
