1. AC Question's Avatar
    I plugged my earbuds into my s6. The external sound did not mute, and the no sound came thru the earbuds. What's up. Note: I changed out earbuds, just in case, the first pair were bad.
    08-25-2015 08:57 PM
  2. the tall guy's Avatar
    Sounds silly but are you fully pushing the ear buds jack into the phone? if the sound is still playing through the phone it means that the ear buds aren't properly connecting - could be a fault with the phone if you've tried a few different pairs.
    08-26-2015 03:30 AM
  3. linebusy's Avatar
    Sounds like they're not fully seated.
    Some cases will prevent some plugs from seating fully.
    If something on the outside isn't causing the plug from seating in the jack, then it must be something internally. Perhaps some pocket lint has gotten trapped inside the jack. Try shaking or blowing out any debris that may be in there.
    08-26-2015 04:50 PM
  1. How to run two apps simultaneously?
    By MisterShark in forum Samsung Galaxy Note 5
    Last Post: 09-14-2015, 09:57 PM
  2. Replies: 2
    Last Post: 08-26-2015, 08:07 AM
  3. How do i save messages on my Samsung 5Galaxy
    Last Post: 08-25-2015, 08:44 PM
  4. How do I get the S5 add call button to work?
    By Jennifer Miliano in forum Samsung Galaxy S5
    Last Post: 08-25-2015, 08:36 PM
  5. Replies: 0
    Last Post: 08-25-2015, 08:11 PM
