1. mogman80's Avatar
    Hi all. I have an S6 and everything seemed to be OK with it until I recently done a software update. Now whenever I try to charge the phone, it gets to 82% and doesn't go any further. It's also now draining incredibly quickly. I wish I never did the update!! Can any body help? Thanks.
    08-28-2015 03:48 AM
  2. razza1987's Avatar
    Try doing a wipe cache partition. If that still doesn't fix the issue back everything up with smart switch and do a factory reset
    08-28-2015 03:52 AM
  3. The Ninja's Avatar
    Make a backup and then try a factory reset, it often solves this kind of problems...
    09-01-2015 07:37 AM
  1. Why won't an app download on my Samsung phone?
    By AC Question in forum Samsung Android Phones
    Last Post: 08-28-2015, 06:26 AM
  2. Replies: 1
    Last Post: 08-28-2015, 04:54 AM
  3. New S6 Edge + amazing homage to Note 4
    By Anthony Martins Rock in forum Samsung Galaxy S6 edge+
    Last Post: 08-28-2015, 02:33 AM
  4. Galaxy S5 Backup Issue, Can I Get Some Help?
    By Kevin Morissette in forum Samsung Galaxy S5
    Last Post: 08-28-2015, 02:07 AM
  5. Why is my Galaxy Tab3 is having microphone problems?
    Last Post: 08-28-2015, 01:51 AM
