1. bkleinkn's Avatar
    I have a Galaxy S6 Edge that has this message flashing on the bottom of the screen all the time. Restarting the handset doesn't fix the issue. It started today and I don't recall doing anything unusual to the phone. I haven't modded or tinkered with the phone at all, it's the same way it was when I bought it new from Verizon.
    Anyone know what is up?
    <<<Apparently I can't post a screenshot. The error at the bottom says, "System encounter error will exit later"?>>>
    09-08-2015 08:55 PM
  2. Gator352's Avatar
    Have you tried a factory reset?
    09-10-2015 04:46 AM
  3. hgstory's Avatar
    Hi bkleinkn,
    It happened to me the same but mine was in Note4, it just happened to be fixed in the way as below, so give it a try.
    1. Open and close your downloaded apps. So that they appear in your recent apps.
    2. Press the left button (recent open apps), swipe to your right everytime the word 'System encounter error will exit later.' DISAPPEAR
    ** The above part is very important, do it only when the words disappear.
    3. Until the error disappear, that is the app that cause you the error. In my case, the app was ZingBox.
    4. Go to 'Settings' > Application manager > Find the app that cause the error > press 'Clear Data'.
    ** Clear Data will clear all your details in the app.
    Or the easier way
    Follow step 1, 2, 3
    4. Uninstall and install back the app.
    Hope the info could help.
    (It is annoying to register and reply, my 1st post and probably last post here, Good Luck!)
    09-25-2015 04:45 AM
  4. Brandon47700's Avatar
    Thanks bro! Mine was also caused by ZingBox
    10-31-2015 12:37 AM
  5. ken_zeppelin's Avatar
    Mine was also from ZingBox :/ thanks!!
    12-17-2015 06:40 PM
  1. Replies: 2
    Last Post: 10-15-2015, 01:58 PM
  2. Why won't Google Play load?
    By AC Question in forum Google Play Store
    Last Post: 09-08-2015, 08:40 PM
  3. Digiland d1010q will not move apps to sd card. Why is this?
    Last Post: 09-08-2015, 07:55 PM
    By AC Question in forum LG L Series III
    Last Post: 09-08-2015, 07:38 PM
  5. Replies: 1
    Last Post: 09-08-2015, 07:09 PM
