1. sayyaf khan's Avatar
    S6 is my first Samsung device so I am new to this power saving mode . How Good is it in terms of increasing battery life ? And how much of a performance hit the phone undergoes with it ?
    10-04-2015 08:13 AM
  2. srkmagnus's Avatar
    It depends on how aggressive you set it. Just know that the more aggressive it's set the more features that will be disabled. For example, GPS will be turned off and if you rely on it for maps or searching for local results, then that's one thing you won't have access to unless you disable the battery saving mode.
    I always suggest disabling things manually. This way you know what's being disabled and can leave on whatever it is that you use.
    10-04-2015 10:04 AM
  1. Replies: 6
    Last Post: 10-15-2015, 06:34 AM
  2. Share burst mode photos on Nexus 6P
    By Zehata in forum Nexus 6P
    Last Post: 10-05-2015, 09:02 AM
  3. How do I download and save music on the LG G4?
    Last Post: 10-04-2015, 08:09 AM
  4. Replies: 1
    Last Post: 10-03-2015, 10:53 PM
  5. Replies: 1
    Last Post: 10-03-2015, 08:59 PM
