1. Ammar7786's Avatar
    i I have a samsung galaxy s6(sm-G920F) on 5.1.1 non rooted, the problem i am facing is that the lte stopped working without any reason, i didnt drop it neither i updated anything it just stopped working now i only see the E sign on the network bar, i couldn't find any answer for this so any help is appreciated
    thanks in advance..
    10-09-2015 02:32 AM
  2. AlphaTango414's Avatar
    Make sure you have mobile data toggled on.
    Check with your service provider to see if their is an outage in your area.
    Try popping out the sim and reseating it.
    Check your APN settings.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    10-09-2015 05:21 AM
  1. [SOLVED] Samsung S6 Edge + auto rotation setting disappeared?
    By eviljim1 in forum Samsung Galaxy S6 edge+
    Last Post: 09-19-2017, 09:23 AM
  2. S6 Edge+ auto rotate setting vanished
    Last Post: 07-24-2016, 05:07 PM
  3. Anybody having problems with the S6 Edge+ dropping network on Verizon?
    By BamaDave in forum Samsung Galaxy S6 edge+
    Last Post: 11-10-2015, 07:33 AM
  4. How To Disable 4G/LTE On Verizon Note 5?
    By JakePleasants in forum Samsung Galaxy Note 5
    Last Post: 10-09-2015, 07:25 PM
  5. The SD card Problem.
    Last Post: 10-08-2015, 10:30 PM
