1. luckystrikes23's Avatar
    So just in the last few days my phone has started having some issues. I got a Powerbot wireless charger(PB1020) about the same time I got my phone at release. It's worked fine , and still does as far as I know. But know, after my phone is fully charged, when I remove it from the charger it's pretty warm(this is a new development, not really had it get very warn on the wireless charger before) and then it begins to connect and disconnect from the wifi repeatedly. I'm talking like every second it switches. I keep seeing people saying to turn off Smart Network Switch, but I did that the second day I had my phone, and it's still off, so obviously its something else. Anyone else had any similar problems and know a fix maybe? I'd hate to have to reset my phone.
    10-17-2015 10:07 PM
  2. bbtkd's Avatar
    Have you tried a reboot? Have you tried clearing system cache? Have you tried deleting and re-adding the Wifi SSID? Have you tried multiple Wifi networks? Have you tried both bands?
    10-17-2015 10:27 PM
  3. luckystrikes23's Avatar
    Rebooting has worked as a temporary fix. And I have tried re-adding the SSID. Never thought about the system cache though. The last two will be a little more difficult, but I'll get back to you on whether the cache wipe helped, or I get a chance to try the other two. Thanks!
    10-17-2015 10:38 PM
  4. luckystrikes23's Avatar
    Well, the cache wipe seemed to fix the problem! Thanks for the help!
    10-18-2015 10:13 AM
  5. Tcbemis's Avatar
    Is Smart Network Switch Sprint? I just got this phone the other day and love it so much more than my old lgg3. My only issue is that at work I can't connect to the secure WiFi and my battery is suffering. I installed the required Smart Connect app (for work), but it's saying invalid password, when I know it's not. I'm wondering if it has something to do with the Smart Switch, but I can't find that in my settings. Thanks in advance!
    10-19-2015 05:58 PM
  1. Replies: 1
    Last Post: 01-17-2016, 07:55 AM
  2. Replies: 3
    Last Post: 10-27-2015, 02:54 AM
  3. Mobilego not reading a SD card on my Google Nexus 5
    Last Post: 10-18-2015, 10:39 PM
  4. Why are certain apps not working on wifi?
    Last Post: 10-18-2015, 02:23 AM
  5. Video Calling not working or Showing Up - Note 5
    Last Post: 10-17-2015, 08:13 PM
