1. doomixy's Avatar
    A few days ago I bought a brand new Samsung Galaxy S6 128GB (SM-G920F). After checking out the camera for a bit I realized there is something wrong. For some reason sometimes there is a glitch while taking a photograph with the flash on. The camera flash occurs, but it doesn't take the photograph. I turn off the flash, take one without the flash (always works) and then I turn on the flash and it works. o.O
    If I close the Camera and lock my phone, and I open the camera again - same thing. I have to do this every single time. It's not a huge problem but a quite annoying one...
    P.S The phone is unrooted & running Lollipop 5.1.1
    Any ideas?
    10-28-2015 06:19 PM
  2. AlphaTango414's Avatar
    Settings>device>applications>application manager>All Tab>Camera>wipe cache
    Also try a 3rd party app to see if you have the same problem.
    10-28-2015 06:26 PM
  3. Tiny Burton's Avatar
    Open the camera
    Go into its settings
    Reset the settings
    Restart your phone
    Open the camera
    Turn on flash on or to auto
    Take a picture 😃
    Tip to auto lock focus, say for close ups... text etc, hold your finger on the screen 😄
    10-28-2015 06:42 PM
  4. Tec12's Avatar
    Hello i too got galaxy s6 sm g920f
    Am facing front camera lag issue in low light.
    Does your camera lag in low light?
    10-29-2015 02:17 PM
  5. AlphaTango414's Avatar
    What do you mean lag?
    10-29-2015 02:43 PM
  6. Tec12's Avatar
    While moving the camera it lags in low light. But as soon as you add some effects its super smooth. And in wide mode also its super smooth
    10-29-2015 03:29 PM
  7. AlphaTango414's Avatar
    See your thread. I replied there.
    10-29-2015 03:41 PM
  1. S4 will say charging but battery life goes down when screen is on.
    By Zachary Gebis in forum Sprint Samsung Galaxy S4
    Last Post: 11-25-2015, 09:36 AM
  2. Love the phone! Some initial thoughts
    By CarbonOak in forum Nexus 6P
    Last Post: 11-05-2015, 10:35 PM
  3. Replies: 1
    Last Post: 10-29-2015, 01:06 AM
  4. Zenfone keeps powering off and on
    Last Post: 10-28-2015, 08:22 PM
  5. Replies: 0
    Last Post: 10-28-2015, 05:36 PM
