1. emad1995's Avatar
    For the longest time Facebook messenger has been at the top of my list for battery drain and i have no idea why, I'm not even using it, is there any way to make it stop?
    11-01-2015 06:20 PM
  2. AlphaTango414's Avatar
    Disable it.
    11-01-2015 06:24 PM
  3. emad1995's Avatar
    Disable it.
    Sorry I think I should be more clear, I use messenger to talk with my friends and Co workers. It's just that on this battery cycle I didn't use it. I don't want to disable the app isn't there another way?
    11-01-2015 07:03 PM
  4. Kelly Kearns's Avatar
    Messenger has been known to use large amounts of battery and data. It seems it isn't an issue they are going to fix.
    11-01-2015 07:11 PM
  5. AlphaTango414's Avatar
    Get Greenify and setup a widget to force close it.
    drone3 likes this.
    11-02-2015 04:21 AM
  6. Edna Alcazar's Avatar
    Delete the application facebook.
    11-02-2015 05:49 AM
  7. emad1995's Avatar
    Facebook is already disabled
    11-02-2015 05:51 PM
  8. MCham's Avatar
    I was having the same issue. Go to Settings-Data Usage. Tap the App you want to stop and scroll down to end. Turn on Restrict Data Usage. If it doesn't show up in Moble Data, it may be in Wifi. You can Restrict All from the More menu top corner but probably you don't want that. Hope it helps!
    11-02-2015 08:12 PM
  9. dominick's Avatar
    Facebook and FB Messenger are pretty much ALWAYS ON. Disabling Facebook was Step 1 for me; it helped a bit. But now that I figured out that Messenger is a battery drain too, I changed settings to have FB text me when I get a Messenger message. If you have a limited text package then perhaps this might not be an option for you; basically I get the text, then I open up Messenger in my mobile browser...
    cheers/dom
    emad1995 likes this.
    11-03-2015 11:02 AM
  10. emad1995's Avatar
    cheers/dom
    Ohh this actually sounds like a good option. Does it text you for every message you get though?? I have this one group with 6 people in it and when they start talking they send at least 300 messages in one go and I would really like to not have 300 Facebook texts in the span of 1 hour lol.
    11-03-2015 01:10 PM
  11. Edna Alcazar's Avatar
    Get rid of it. It is a battery drainer!
    11-04-2015 05:21 AM
  12. dominick's Avatar
    you know, i'm not sure. i haven't played with those settings enough to know how customizable they are. i also don't FB chat much so it was never a concern for me.
    that said, it seems like you can customize just about anything on FB, so i'm hopeful you could make the text-msg option manageable
    cheers/dom
    11-06-2015 02:33 PM
  13. AlphaTango414's Avatar
    Give Trillian, AIM, or IM+ apps a try. They all have FB integrations.
    11-06-2015 06:27 PM
  1. Has Doze increased your battery life?
    By NucleBAH in forum Android 6.0 Marshmallow
    Last Post: 11-06-2015, 06:18 PM
  2. moto x vs note 5 battery life.
    By Phonejock in forum Moto X Pure Edition
    Last Post: 11-02-2015, 11:41 AM
  3. Removing battery to speed up phone!
    By Meogeo51 in forum Ask a Question
    Last Post: 11-02-2015, 08:51 AM
  4. Facebook issues
    By 70dustpan in forum Samsung Galaxy S6 edge
    Last Post: 11-02-2015, 05:52 AM
  5. Hangouts vs messenger .
    By robert7107 in forum Android Apps
    Last Post: 11-01-2015, 06:15 PM
