1. JannesG's Avatar
    It all started yesterday morning. I send a message when suddenly my screen was not responsive.
    I tried a soft reset (power-volume down). That worked but my screen turned out black.
    After +- 20 soft resets my screen finally worked again. But now the top of my screen is unresponsive. It's basically the top 1 cm that isn't responding to touch.
    What should I do?
    Thanks!
    Jannes
    11-08-2015 04:26 AM
  2. jkulmtd's Avatar
    What should I do?
    Thanks!
    Jannes
    If you still have warranty I would go and get a replacement from the store you purchased from
    11-08-2015 09:23 AM
  1. How to disable all voice and talkback functions?
    Last Post: 11-08-2015, 04:17 PM
  2. Replies: 1
    Last Post: 11-08-2015, 04:16 PM
  3. Galaxy S6 - Why isn't the top of my screen responding to touch?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-08-2015, 04:14 PM
  4. Where do I go to turn the speed engin on my Samsung Centura?
    Last Post: 11-08-2015, 06:44 AM
  5. Can't seem to turn off keystroke sounds in Nexus 5
    Last Post: 11-08-2015, 06:40 AM
