1. AlphaVictor87's Avatar
    I don't understand this thing at all. I use it at work now because as a night time charger it was really annoying waking up to a phone that was only at high 80% - low 90% in charge.
    Now i'm just having really weird issues. The phone stops charging around 92 - 93%. This is almost every time i use the charger. The light on the pad is blinking blue I pick it up and put it back down and it continues to charge. All for another 1 or 2 % then stops again. rinse and repeat.
    Sometimes when it stops before 100% the charger gets "stuck" and continues to blink blue and will not charge until i unplug the pad and plug it back in.
    I just now had the pad showing green indicating it was at 100% when my phone was at 94%.
    Is there any chance taking this thing to a Samsung experience store in a Best Buy will get me a replacement?
    EDIT: No luck talking directly with Samsung, they just said "go to best buy"
    11-12-2015 09:33 AM
  2. Gator352's Avatar
    I've read threads about the samsung wireless chargers not working correctly. I'd take it to best buy and see what they can do for you. If nothing, then get yourself a choe charger on amazon. Been using the same one for a year now without any problems.
    11-13-2015 10:53 AM
  3. ziggster's Avatar
    Save yourself some heartache and buy a new charger.
    11-13-2015 11:01 AM
  4. makaroni's Avatar
    Mine used to stop at about 98% but ever since the 5.1.1 update, it goes to 100. Update seemed to correct the issue. Have you received the update yet?
    11-14-2015 02:22 AM
  5. Mike Ramsey1's Avatar
    I have the Verizon charger that is also a stand its never give me any problems and you can charge your phone and watch videos in landscape
    11-14-2015 03:30 PM
  6. dwatcool's Avatar
    I will admit I have the same charger, Same issue. However I have found that there is a "sweet spot" on the samsung charger plate. Here's what I do. Place phone on center of plate then slide phone up about 1/4 inch. So the top of the phone hangs over more on the top of the plate.
    I am too looking for a replacement charge plate other than samsung. Any suggestions?
    11-14-2015 03:52 PM
  7. acles003's Avatar
    Have had S6 since April. Wireless charger worked fine. Then all of a sudden I need to keep readjusting to find the sweet spot. Now, I put my S6 on the charger and... Nothing. Doesn't even register that they are touching. Thought it was the charger but I just got a Moto 360 and as soon as I put it on the Samsung charger, it started charging in 2 seconds.
    Is my phone defective?
    11-18-2015 07:30 PM
  8. blevitt3's Avatar
    Same here...takes forever to find the exact perfect spot...
    11-20-2015 01:41 PM
  1. Replies: 2
    Last Post: 12-26-2016, 11:30 AM
  2. Issues with my Moto 360 2015, how can I fix it?
    By gagan in forum Moto 360 (2015)
    Last Post: 12-17-2015, 05:15 PM
  3. Does it have GPS and/or NFC?!
    By fishmd in forum LG Watch Urbane 2nd Edition
    Last Post: 11-20-2015, 08:43 PM
  4. Replace Moto Connect with....?
    By Rick Jacobs in forum Moto X (2014)
    Last Post: 11-13-2015, 02:24 AM
  5. Replies: 0
    Last Post: 11-12-2015, 08:17 AM
