1. sbrisu's Avatar
    Hi everybody,
    My Samsung S6 "Add fingerprint" function freeze and I can't add any fingerprint... the white screen with instruction remains "Place finger on Home key, lift it off, etc" but nothing happens when I put my finger on & off.
    The already installed fingerprint that I set at the beginning works fine, so I presume is an Android bug... anyone else experienced this?
    11-19-2015 04:06 AM
  2. AlphaTango414's Avatar
    Wipe system cache via recovery and try again. I'd assume you have tired to do a simple reboot?
    11-19-2015 05:07 AM
  3. sbrisu's Avatar
    Thanks dumpedduce, yes I tried the reboot and also the wipe system cache, and notyhing change... there is the possibility to install single system apps, like Fingerprint alone?
    11-19-2015 05:21 AM
  4. AlphaTango414's Avatar
    You can try to see if it will do anything for you.
    Fingerprint System APK
    11-19-2015 06:41 PM
  5. sbrisu's Avatar
    Thank you so much, how can I install an .apk file and where did you find it?
    I am completely new to Android...
    11-20-2015 04:15 AM
  6. AlphaTango414's Avatar
    Download the apk. Click on it through the file Explorer and it should automatically pop up asking if you want to install. I got the apk from my phone by using an apk extractor.
    11-20-2015 05:41 AM
  1. New to Android from Blackberry - Help choosing a phone.
    By Doggerz in forum New to the Forums? Introduce Yourself Here!
    Last Post: 11-26-2015, 01:12 PM
  2. Replies: 2
    Last Post: 11-20-2015, 08:49 AM
  3. how do I connect to wi-fi, are there any specific settings ?
    Last Post: 11-19-2015, 10:10 PM
  4. Replies: 1
    Last Post: 11-19-2015, 05:33 PM
  5. How do I insert my name on my home screen?
    Last Post: 11-19-2015, 06:31 AM
