1. Dannyr05's Avatar
    I've got a Galaxy S6, the official charger that came with the S6 and the official wireless charger. I get a blinking green light when I plug the wireless charger in which indicates the wall charger is under 2A, but the charger is (it's the official charger which Samsung have confirmed is sufficient).
    Anyone got any advise?
    11-23-2015 03:40 PM
  2. SpookDroid's Avatar
    Check your cable. I've had issues with faulty cables where the stock charger will not supply enough current. Once I replaced the cable, it worked without issues.
    11-23-2015 03:45 PM
  3. Dannyr05's Avatar
    Are there any ways to check the cable or is it just best to take it in store.
    11-23-2015 03:56 PM
  4. Dannyr05's Avatar
    Ok so I took my phone out of the case again and this time it went to a solid green. I have the official S View case, isn't that meant to be compatible?
    11-23-2015 04:00 PM
  5. SpookDroid's Avatar
    It should be, but I haven't seen anything that says otherwise... You might have to place it differently when you have the case on then. Try placing it lower or higher or sideways to see which one works best.
    Without the case if I place it with the top of the phone too low on the charger, it will blink.
    11-23-2015 04:07 PM
  6. Dannyr05's Avatar
    It will only charge with a blinking light in a pretty central position, any higher or lower and charging pauses.
    11-23-2015 04:10 PM
  1. Samsung Gear S2 (T-Mobile) with Verizon Phone?
    By jeff1penny in forum Samsung Gear S2
    Last Post: 12-03-2015, 02:52 PM
  2. Qi wireless receiver
    By Vizi in forum LG V10
    Last Post: 11-28-2015, 08:02 AM
  3. Notification sound issues on Samsung S6 64gb, can I get some help?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-24-2015, 01:35 PM
  4. Replies: 1
    Last Post: 11-23-2015, 09:51 PM
  5. Why is my Samsung Qi Wireless Charger blinking green?
    Last Post: 11-23-2015, 03:22 PM
