1. AC Question's Avatar
    I've had my galaxy s6 since the beginning of summer and haven't had any issues with it. Recently it has been taking either forever to charge (even while it said fast charging enabled) and sometimes wouldn't even charge just hold the battery percentage in the same place. I would go to sleep and wake up to the same percent that I left it at. I am fed up and desperate for answers because now it does not say fast charging is enabled, just normal cable charging and my battery just keeps getting lower, it doesn't seem to charge at all.Also i went to my battery settings and there is no check box or whatever there should be for fast charging like I've read elsewhere. Im hoping it is an issue with the charger, not the phone but I do not have another charger to try it with.
    12-15-2015 09:14 AM
  2. dpham00's Avatar
    Do you have a computer? You can try to charge off of that with the screen off.
    12-15-2015 09:31 AM
  3. Travo79's Avatar
    Have you tried a different USB cable? You could have a bad cable or charging brick.
    12-16-2015 11:19 AM
  1. My Galaxy S5 wont allow me to move anything onto SD card
    By AC Question in forum Samsung Galaxy S5
    Last Post: 12-15-2015, 12:20 PM
  2. How can i open my Galaxy Note 3, if i forgot my password?
    By tarapj4@yahoo.com in forum Samsung Galaxy Note 3
    Last Post: 12-15-2015, 09:37 AM
  3. Replies: 1
    Last Post: 12-15-2015, 09:32 AM
  4. How to switch off 'imessage' for Android? help
    Last Post: 12-15-2015, 08:28 AM
  5. Why is my Galaxy S5 screen going off during calls?
    Last Post: 12-15-2015, 08:23 AM
