1. Amit Agarwal5's Avatar
    It's been a week using edge plus and it's been awesome. However today I noticed a slight detoriation in camera quality. And then I noticed the IR sensor is not flickering red as it used to earlier.
    I have recently upgraded software via OTA
    But not sure if it happened after the upgrade.
    Now focusing in low light is also not possible without flash. Please guide me if it's hardware issue or software , I mean is there a way to check the same.
    01-03-2016 12:04 PM
  1. If OTA image is not available for sideloading, must I flash?
    By dcheest in forum Android 6.0 Marshmallow
    Last Post: 01-03-2016, 11:49 AM
  2. extend ringtime on galaxy s6
    Last Post: 01-03-2016, 11:34 AM
  3. My. LG 4G LTE VS950 is stuck in a bootloop please help
    By Naturalgal 99 in forum Ask a Question
    Last Post: 01-03-2016, 11:16 AM
  4. I am setting up my desire 626
    Last Post: 01-03-2016, 10:36 AM
