1. xpsd300's Avatar
    I'd like to be re-asked all of the questions when I turned the phone on for the first time, such as language preference, time/date, wifi settings, etc.
    The model # of the phone is SM-G920TZKAX (unlocked).
    Thanks.
    01-07-2016 11:57 AM
  2. LeoRex's Avatar
    Unless you modified the system software, you will get asked the same series of questions.
    01-07-2016 12:21 PM
  3. xpsd300's Avatar
    Does it matter which method I use?
    (a) Apps -> Settings -> Backup & reset -> Factory data reset -> Reset phone -> Erase everything
    (b) Volume Up + Home + Power -> Wipe data/factory reset
    01-08-2016 03:49 PM
  4. Kelly Kearns's Avatar
    (a) Apps -> Settings -> Backup & reset -> Reset device -> Erase everything
    Personally, I prefer the last method for reset.
    Also don't forget to remove your Google account before reset or you will have to enter that to even set up the phone.
    01-08-2016 04:11 PM
  5. xpsd300's Avatar
    Great. Thanks!
    01-08-2016 04:54 PM
  6. leprechaunshawn's Avatar
    Is there a difference in what A and B do?
    01-09-2016 10:15 AM
  7. Kelly Kearns's Avatar
    I couldn't tell you, I haven't used the reset from the menu since Gingerbread.
    01-09-2016 10:32 AM
  1. 6.0 Marshmallow: Europe (XT1541) roll out
    By NucleBAH in forum Moto G (2015)
    Last Post: 02-27-2016, 03:36 AM
  2. Note Pro 12.2 issue with OTG connection of external 500GB Samsung T1 SSD
    By spazzbecker in forum Samsung Galaxy Note Pro 12.2
    Last Post: 02-17-2016, 04:12 PM
  3. Why are actual device names in the dictionary
    Last Post: 01-07-2016, 01:24 PM
  4. Replies: 1
    Last Post: 01-07-2016, 01:22 PM
  5. Google Now empty home screen question..
    By sniffs in forum Android 6.0 Marshmallow
    Last Post: 01-07-2016, 11:36 AM
