Samsung s6. Battery drain
Hi all
Got my new Samsung s6 a week ago and loved it until. I noticed the battery drain. I end up charging the phone at least 2-3 times a day just to keep me going.
I use the Samsung fast charge that came with the kit to to charge.
I don't watch videos, listen to music or pay games all I do is check messages, read emails and browse the net. The battery just is ridiculous. I usually leave it to charge over night.
One example :
Was 100% charge at 9 am. By 1 pm I noticed it was already down to 35% on normal use. I admit I check the phone now and then for messages and stuff.
I tried everything from downloading greenify to hibernate apps. Cleared partition cache, disabled most apps, regularly close all apps from the task manager as well as smart manager. Set screen brightness to as low as possible.
Not sure what else to do
I downloaded gsam to monitor the battery drain and shows android system use about 50% of battery and the rest is the screen.
Any thoughts??? I just recharged the phone so no point taking a pic of the battery stat's. I'll wait for it to drop to around 50% and the add a pic
Any help will be much appreciated
Thanks
Hi all
One example :
Thanks
