1. Find000's Avatar
    Please watch the link if it works, thanks. (remove spaces)
    youtube . com / watch?v= JCJHGXGCUAQ
    Hi I have the Samsung Galaxy S6 from Rogers, and sometimes when listen to my music, my songs seem to be skipping/ stuttering like in the video. It happens when im playing games, listening to music, any social media video, youtube. I was wondering what could be the problem, if there's something in the settings or its just a defective phone. The way I get rid of the problem is either closing the app several times or restarting my phone, but I do this way too often. I have already factory reset this phone twice, and its a pain in the *** to put all my apps back, but if I have to do it I will. If anyone knows anything about this problems let me know. Thank you.
    02-28-2016 02:57 PM
  2. nahoku's Avatar
    Sounds bad! Does this also happen directly after a factory reset and before you install all your apps? Maybe one of your apps is causing the problem. Try starting your phone in Safe Mode, turn off your wifi and data connection, and play your music again. If it still doesn't work, then it might be a hardware problem.
    02-28-2016 04:02 PM
  3. tfaris99's Avatar
    I have this same issue, did you find a fix?
    08-23-2017 05:44 PM
  1. Why am I missing the top banner with images in the Play Store?
    By Gabriel Silva Cheinquer in forum Google Play Store
    Last Post: 05-16-2016, 07:51 PM
  2. S PEN on NOTE 5 just stopped working!
    By eugchen in forum Samsung Galaxy Note 5
    Last Post: 03-02-2016, 01:42 AM
  3. How do I remove downloads from my Android?
    Last Post: 02-28-2016, 04:09 PM
  4. Replies: 0
    Last Post: 02-28-2016, 04:07 PM
  5. How to raise S-voice feedback through speakerphone
    By weiss1173 in forum Samsung Gear S2
    Last Post: 02-28-2016, 03:33 PM
