1. TomRawlo's Avatar
    Hi, in the past few hours my Galaxy s6 running marshmallow has started telling me that it is overheating and turns itself off. It also won't let me charge the phone. Has anyone had this problem before or found a solution for it? Thanks!
    03-21-2016 05:36 PM
  2. zunaer's Avatar
    Could you screenshot it when it says its overheating and it may just be a bug in the software
    03-21-2016 05:41 PM
  3. TomRawlo's Avatar
    I can't it won't let me use any apps other than the phone and contact because it says it is too hot. Then after a minute or so it starts shutting itself down
    03-21-2016 05:51 PM
  4. zunaer's Avatar
    Have you tried a factory reset?
    03-22-2016 02:09 AM
  5. lucianus_luciferus's Avatar
    look inside the charging port and the headphones socket and see if theres something shorting the pins
    03-22-2016 03:48 PM
  1. Replies: 134
    Last Post: 11-18-2017, 08:49 AM
  2. Replies: 29
    Last Post: 06-30-2016, 11:54 PM
  3. Replies: 12
    Last Post: 03-24-2016, 10:16 AM
  4. Replies: 2
    Last Post: 03-22-2016, 01:14 AM
  5. Replies: 1
    Last Post: 03-21-2016, 05:22 PM
