1. cgozzett's Avatar
    Hi,
    Please help, my S6 is only 2 months old, I recently update it to Marshmallow about 2 weeks ago and the speaker sound has started breaking up when playing music or watching videos via all apps (i.e. iplayer/youtube, etc.) The sound is fine for a couple of seconds then starts breaking up. Not sure if its a software issue due to upgrading to Marshmallow or just a coincidence? Or maybe its a hardware issue. But it doesn't happen everytime, just happens randomly.
    Below is a youtube link to what it sounds like when its breaking up:
    -------https://youtu.be/kejWmPRKIFk-------
    Please help
    03-23-2016 08:27 AM
  2. lucianus_luciferus's Avatar
    try formatting cache partition. if it still does not work then you might have to do a factory reset
    03-23-2016 03:39 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Steps for wiping the cache partition can be found here: https://support.t-mobile.com/docs/DOC-21095.
    I would also try Safe Mode, to see if the problem is due to a 3rd party app: https://support.t-mobile.com/docs/DOC-21007
    03-23-2016 03:45 PM
  1. [FREE] Doninn Audio Cutter
    By Don inn in forum Android Apps
    Last Post: 04-21-2018, 08:27 AM
  2. Samsung Galaxy Alpha Custom or wait for official update?
    By AC Question in forum Samsung Galaxy Alpha
    Last Post: 03-23-2016, 03:55 PM
  3. Samsung S6 unable to change volume
    Last Post: 03-23-2016, 09:05 AM
  4. Samsung S6 unable to change volume
    Last Post: 03-23-2016, 09:04 AM
  5. PDF Help
    By Contina Banks in forum Ask a Question
    Last Post: 03-23-2016, 07:32 AM
